Toll Free (888) 468-6158  | About | Contact | RSS Feed
Motorola Droid Batteries
1. Motorola Droid Motorola BP6X Standard Battery
Motorola BP6X Standard Battery for Droid (A6183)
Specifically for the Motorola Droid the Motorola BP6X Standard Battery ensures that your Smartphone will always be power up and ready.
$29.95
(8)
In Stock Add to Cart
2. Motorola Droid Seidio Innocell 1350mAh Replacement Battery
Seidio Innocell 1350mAh Replacement Battery for Motorola Droid (A6391)
The Seidio Innocell 1350mAh Replacement Battery fits in your device's existing battery space and doesn't require a replacement door, which makes it a perfect replacement or addition to your original battery.
$29.95
No User Ratings
3. Motorola Droid Seidio Innocell 2600mAh Extended Battery
Seidio Innocell 2600mAh Extended Battery for Motorola Droid (A6360)
The Seidio Innocell Extended Life Battery is for the avid traveler who can't always get to a charger. It has up to 87% more capacity than the original and comes with a black replacement door featuring Seidio's signature soft touch coating.
$64.95
(13)
